Ana içeriğe geç
PS3 ile birlikte gelen kontrolörler için onarım ve destek. 2007 (yalnızca Japonya) ve 2008 (diğer ülkeler) Kasım aylarında piyasaya sürülen altı eksenli lityum pille çalışan kontrol cihazının (CECHZC2) onarımı oldukça basittir.
Need Help Diagnosing PS3 Controller Ghost Inputs (MCU V3.5x 1.12)
Hello, I’m struggling with ghost inputs on a DualShock 3 (MCU V3.5x 1.12) with a Toshiba T6UN6EFG-002 Japan 0833EGIF0461ZAO. I’ve tried cleaning and reassembling, but the issue persists. Any advice would be appreciated!
Problem:
  • Ghost Inputs: Pressing one button triggers multiple inputs (e.g., Square causes random b, w, [, ], a, 1 combinations.). [ for context: the reWASD mapping is in the photos link ]
  • Pattern: After connecting via USB, the controller outputs [[[]]]]] after ~15 seconds.
  • Multimeter Fix: Dragging the red(signal) probe across all pins temporarily stops the issue.
What I’ve Tried:
  1. Disassembled, cleaned PCB
  2. Tested button continuity with a multimeter (Square=TP30, X=TP31, TPs to Toshiba pins, connectors up to the white boarder).
  3. Confirmed the issue occurs wirelessly and via USB
Limitations:
  • No soldering tools yet.
  • Can’t identify shorts or damaged resistors.
I removed everything and left the PCB only to be sure that the problem isn't from anywhere else. I bridged the pins with the help of wires, paper clip and other metal conductive object.
Any tips what to look for? What else can i try? Any ideas where the problem could be?
Link to photos: https://mega.nz/folder/oigjFaiI#7NXMg2_7...
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi!
It's a common issue for the Dualshock 3 to ghost after some time.
I replace the Button Circuit Membrane all the time and this actually always work.
So, I recommend to do this and see how that goes.
If you need any guides, please let me know!
Thanks!
Bu yanıt yardımcı oldu mu?
Puan 0
4 Yorum:
Would replacing the membrane work even when i tested it through the PCB and still gave errors?
tarafından
For me it does. It's worth the try! Usually this is the golden fix.
tarafından
@dan0 k then. i will order a membrane from ali and see how it goes
tarafından
Alright! Please keep us updated! Thanks :)!
tarafından
Yorum Ekle
Yanıtını ekle
User 1 Here sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 151
