Ana içeriğe geç
A HD pocket camcorder to compete with Flip mino/ultraHD. Many view the Kodak Zi8 as having a better set and a camera worth considering more then the Flip.
Why does the camera run down in ten minutes?
I charge the camera - with several new batteries - and it runs down within ten minutes. How can I fix the charging mechanism?
Bu iyi bir soru mu?
Puan 0
1 Yorum
I have tried four new batteries, and two new battery chargers - and also charging it from the computer.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Because the battery in your device has aged, if possible, you can replace the camera or buy a battery to replace it
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
tarafından
@jmartz42667 Fast power consumption solution: Turn off WIFI: WIFI function can be turned off when not in use to reduce power consumption. Adjust backlight and warm light settings: Reducing backlight and warm light can lower power consumption. Waiting for the download and indexing process to complete: After the device completes the download and indexing process, power consumption will return to normal
tarafından
Yorum Ekle
Yanıtını ekle
jmartz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 90
