Ana içeriğe geç
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
What do these connectors do?
What do each of these three cables / tiny connectors do?
I accidentally knicked one of them a little (I think the one most to the left). Everything still seems to work fine, but maybe I just don't know what to look for...
Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@carl_jfischer These are coaxial cables, meaning they have an inner core of a single strand of wire. That wire is covered with insulation, then a sheath of woven mesh wire covers that. That sheath provides a shield for the inner cable to insulate it from outside signals and keep it from broadcasting signals. That outer sheath is covered with a layer of rubber as insulation.
So it really depends on what kind of damage you did to the cable. If you just nicked the rubber insulation on the outside, then there's really nothing to do; you haven't damaged the signal integrity of the center wire at all. Even if you've done a little bit of damage to the woven sheath, that's not necessarily any big deal either, as long as you haven't broken the inner insulation and cut the center wire.
Just to be safe, it wouldn't hurt to wrap a piece of electrical tape around the torn part, but as long as everything is working it doesn't look like you've done any significant damage. My vote would be to leave well enough alone and don't worry about it unless you notice issues with any of your radio signals, including cellular, wifi or bluetooth.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
WiFi antennas diversity array, losing one of them may not cause apparent symptoms if it’s not the primary one, just lose 1/2 or 1/3 of the speeds.
Puan 0
8 Yorum:
Are they replacable?
tarafından
@carl_jfischer Not possible without replacing the whole screen.
tarafından
@tomchai - This series of MacBook Pro has a removable antenna assembly like the older 2011~2012 models. You can replace the one cable or the full assembly.
tarafından
@danj isn’t it wrapped into the hinge with the camera cable? In that case it can be tricky to pull just the WiFi cable from the hinge.
tarafından
@tomchai - No hard than threading a needle😁
tarafından
3 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Carl Fischer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 110
