Ana içeriğe geç
Dell Latitude E5570 için onarım bilgileri ve sorun giderme. Bu cihaz, 6. nesil Intel Core işlemciye sahip 15,6 inçlik bir iş sınıfı dizüstü bilgisayardır. 2016 yılında piyasaya sürülmüştür.
Black screen of death
So when I turn on my laptop I get greeted with a black screen, some trouble shooting I have done it trying to reinstall windows (I still saw black screen), when i press caps lock nothing happens, when I try to open bios nothing happend, i have tried reseating ram, using a differant hard drive, doing a hard reset, took out the cmos battery then put it back in, tried plugging it into moniter with hdmi and vga, nothing works,
Any help would be appreciated.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Does the screen turn on but not show anything or can you see the backlight on?
tarafından
@uptempoguy the backlight is not on at all. the screen is copletely black, same as when its turned off
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
@heathbrown43963 check your backlight (most likely not the issue sine you also have no pictures on an external monitor). Turn your computer on and in a darkened room, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
It is possible that this is a bad BIOS. You may need to consider reflashing it. Of course, there is also a possibility that this is a failure of your GPU circuitry on your motherboard.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Heath Browning-Davies sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 344
