Ana içeriğe geç
2015 yılında piyasaya sürülen Republic of Gamers dizüstü bilgisayarı. GL551J, GeForce GTX 860M ekran kartına ve 15,6 inç Full HD 1080p ekrana sahiptir.
tab key is not working
keyboard tab key is not working
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Well you try the different keyboard and check if the tab key is work or not of that keyboard as well and also check for the outdated keyboard driver as well some time an outdated driver can be the reason of this kind of issue as well you can check the driver manually or you can check the outdated driver with a good tool which can help you in update the driver as well like Advanced Driver Update or any other good driver updater tool.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Well you try the different keyboard and check if the tab key is work or not of that keyboard as well and also check for the outdated keyboard driver as well some time an outdated driver can be the reason of this kind of issue as well you can check the driver manually or you can check the outdated driver with a good tool which can help you in update the driver as well like Advanced Driver update or any other good driver updater tool.
Puan 0
Yorum Ekle
Yanıtını ekle
German T sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 193
