Ana içeriğe geç
Model A1502 / 2.6 GHz (3.1 GHz'e kadar Turbo Boost) veya 2.8 GHz (3.3 GHz'e kadar Turbo Boost) 4 MB paylaşımlı L3 önbelleğe sahip çift çekirdekli Intel Core i7 işlemci.
Fix keybord cable before replacement
I need to replace the keyboard of my MBP because sone key stopper working and I think it’s because the connector is damnaged. Before proceed, I’ve searched here some similar questions and found also one where there is an attacched video with the needed steps. I’m looking for a written guide I can follow, but my question is, can I fix only the connector instead of replacing the whole keyboard? To do the fix I need to remote the battery and display or I can avoid? If I Remo e the battery how I will put it in place again, is there a special take I can found on Amazon that I can use?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I have made written guides for many models but ifixit has yet to approve them.
MacBook Pro 13" Retina Ekran 2015 Başı Klavye Değişimi
You'll have to remove the battery to change the keyboard, as the keyboards cable is part of the keyboard, and also to get to the track pad and it's cable, I would check this cable 1st as it is replaceable, check to re connect it 1st. and also any think double sided tape should be strong enough to hold the battery in its place again afterwards.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
The 2015 model have sone differences with the mid2014?
tarafından Paylaş
@ziobru The exact guide for the 2014 model has yet to be published by ifixit. It is the virtually same procedure anyway.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
B1P sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 31
Her zaman: 325
