Ana içeriğe geç
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
310 Soru Tümünü görüntüle
check lent filter light on and will only run on express dry
My Kenmore Elite Dryer has the check lint filter light on and will only run on the express dry cycle, I cleaned the lint out of the lint trap area and vacuumed the rest of the area, the dryer turned on on a different cycle as a test run, but when to dry the next load it went back to the express dry cycle, and check the lint filter light is back on, what more can i do as have not found a troubleshooting guide for the model i have.
Bu iyi bir soru mu?
Puan 1
3 Yorum
If you have a Save Energy button and only after you have checked filter and made sure the duct is clean, press and hold the button for 3 seconds!
tarafından
This is the right answer. I already knew it was locked, because my washer had the same issue. All the talk about cleaning filter is wrong. You just need to hold the save energy button for 3 seconds on the dryer. The washer requires holding 2 buttons simultaneously and you can find instructions on the quick reference guide.
tarafından
My dryer says to check the lent trap the control board comes on but the dryer don’t work on any setting !! Help !
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Linda, if the answer from mayer should not work, keep in mind that the "Check lint screen" light is just a reminder to check and clean the lint screen before or after each load. There is not a sensor that will detect if it's clean or dirty. The "Check lint screen" should turn off as soon as the dryer is started. Check the wire harness connections between the console and the electronic control board. If it never turns off then the control board might need to be replaced. You should run a diagnostics on your dryer. Check on here to see how to get into the mode. You can download the service manual for your dryer from here. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
your link on how to check mode is not working
tarafından
@tonihayes darn those links didn't even last 11 years :-) What make and model is your dryer and you have the same light on?
tarafından
Yorum Ekle
Try unplugging it for five minutes. This will allow it to reset and maybe see that the filter is now clear.
Puan 2
Yorum Ekle
Check the vent where it exits the house. Go outside and look inside the vent cover. Lift the flap where the vent exits the house. I just learned last night that there is another filter tucked away inside the flap. Mine was plugged solid with lint. Today our dryer is working great. Need to check the filter twice a year. I have added it to my daylight saving task. Change the time and the batteries in the smoke alarms and clean the outside driver vent filter.
Puan 0
Yorum Ekle
Press and hold Save Energy button for 3 seconds. That resets it. Make sure you first checked and cleaned any blockage and washed your filter.
Puan 0
2 Yorum:
my model does not have a Save Energy button. What is the substitute for model 61523210?
tarafından
Pressing that button for 3 seconds, doesnt work anyway.
tarafından
Yorum Ekle
Yanıtını ekle
Linda sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 40
Son 30 gün: 174
Her zaman: 55,448
