Ana içeriğe geç
Model A1312 / 2011 Ortası / 2.7 & 3.1 GHz Core i5 veya 3.4 GHz Core i7 İşlemci, Kimlik iMac12,2
iMac wont boot after Reseating RAM.
I wanted to add more ram to my 2011 27 inch iMac. I added two more sticks which caused the three beeps. I removed those two and it still did it. After reseating the oem ram, the iMac wont turn on. The only thing that happens is the fan turns on and off again and again and LED 2 turns on and off with the fan. Now, when trying to put the ram back in, only one slot clicks in. I tried all four sticks of ram in another device and they work. Pls help
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The slots are a bit tight in this series. Make sure you haven't damaged the slots but using the wrong SO-DIMM's the different versions have different keying. Compare the Apple units against what you bought.
Bu yanıt yardımcı oldu mu?
Puan 1
23 Yorum:
I’m currently using the original ram sticks
tarafından
@dhusanthb - I understand, but the other SO-DIIMs might have damaged things, which is why I wanted you to compare the two.
tarafından
The RAM sticks work on another device
tarafından
@dhusanthb - I have no doubts! But what IS the other device? Another Mid 2011 27" iMac?
tarafından
It was an HP Elitebook 840 G1
tarafından
18 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Dhusanth B sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 10
Son 30 gün: 15
Her zaman: 253
