Ana içeriğe geç
Ninja Foodi SP101, hava fritözü, ekmek kızartma fırını ve konveksiyonel fırın olarak çalışan dijital bir hava fritözüdür.
How to Remove Side Panel?
I have been struggling to get the side panel on this removed. I am aware the guide here says to unscrew the 3 screws and then push the panel towards the control panel until the clips are visibly detached
However I have not been able to produce this result with varying levels of force. There is something towards the control panel that is firmly holding that side of the panel in place no matter what I try.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
It works with light force, so there's probably still a hidden screw that needs removal. For me, it was the TR10 (security Torx) on the inside left front wall middle near the door, covered in grease. So in total you remove the black plastic bar screws, the back panel screws on the side you want to remove, and the screws underneath the bottom flip tray on the side you want to remove.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Luke Davis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 21
Son 30 gün: 61
Her zaman: 339
