Ana içeriğe geç
Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
Magsafe 3 blinking orange slowly and Mac not turning on
My MacBook Pro M1 Pro (A2442) recently stopped turning on. Whenever I try to charge it the Magsafe 3 led blinks slowly in orange and even if I leave it for 30+ min it doesn't turn on. I have tried with USB c charging as well and it doesn't turn on.
I haven't used this Mac much so I usually only turn it on every month and the battery is dead so I have to charge it for 10 min or more before it can turn on on 1% battery and I can use it. I also usually don't turn it off and I guess it turns itself off by running out of battery.
Do I need to change the battery or how can I what's wrong with it ?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
If you let the system sit for long periods of time your battery maybe the issue. Review this guide MacBook Pro 14" 2021 Battery Replacement what you want to do is disconnect the battery to see if you can run the system directly on the Charger Alone.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
So that is the test I can do ? Follow the guide until the point of disconnecting the battery and then reassemble and try tu turn it in like that ?
I guess the system will let turn on the Mac without battery 🤔 (no battery error?)
tarafından
@xry1unaepbauzo - just leave the battery disconnected and leave the cover off. I haven't checked the 2021 systems yet as they held up quite well.
tarafından
Yorum Ekle
Yanıtını ekle
pegongorasep sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 51
Her zaman: 398
