Ana içeriğe geç
2010 Ortası Model A1278 / 2,4 veya 2,66 GHz Core 2 Duo işlemci
MagSafe DC-in board compatibility
I have a 2010 MacBook Pro that I'm reassembling for somebody.
For some reason, the MagSafe DC-in board that was included was part number 820-2361-A. The connector to the motherboard fits, but the holes for connecting to the case are misaligned. I realize that I'll need part number 922-9307 or 820-2565-A.
I'm wondering if I can use the 820-2361-A for this model instead of buying the new part, and just keep one screw installed and deal with it.
So, can I use the 820-2361-A without fearing that it'll fry my motherboard?
The attached photo is what came with the MacBook that doesn't fit.
This is the part I need: MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
Resim
Replace a damaged or malfunctioning magnetic DC power connector. Görseli
Ürün
$9.99
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Well... The DC-In Boards are electrically the same. But the physical difference you discovered with the alignment will be an issue as the pressure of the connection won't be firm. So for now use it to test the system and snag the proper one so it's correct.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
S.I. Dalton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 196
