iPhone X screen keeps going black
It's just that the screen is coming off, from all 4 corners. I dont know what to do if i take the screen off. What should i do?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Well I will suggest yo to watch the following video it might help you in fixing the issue with your iphone:
Bu yanıt yardımcı oldu mu?
the screen is popping off a bit, it fell down and since then it just keeps going black. If i dont press on the screen it goes black, if i apply pressure it doesnt
This won't help with a hardware problem with the screen. All you're doing is a hard reset, which is frequently useful but not in this case.
I have the same thing happening to my XR. Is the entire screen popping out or just like the front glass? Because on mine if you look from the top you can actually see the backlight of the screen as it is actually separating instead of coming off. Are you still able to sometimes use it, and does the touch work?
If the screen is coming off it's usually a swollen battery causing it. Open it up and see if it's swollen. It'll need replaced if it is.
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 241
