Ana içeriğe geç
Malibu, 2008 yedinci nesli için yeniden tasarlandı. Bu nesil Malibu birçok donanım seviyesiyle piyasaya sunuldu: Base (sadece 2008) (1SB), LS 1LS (veya 2011 ve 2012 filo modelleri için 1FL), LT 1LT (veya 2011 ve 2012 filo modelleri için 2FL), Hybrid (sadece 2008 ve 2009) ve LTZ 1LZ. Sadece en üst seviye LTZ donanım paketi kırmızı LED ışıklı şeffaf fren lambası camlarıyla donatılmıştı; diğer donanım paketleri ise geleneksel fren lambası ampulleri bulunan kırmızı camları korudu.
back window wont roll up
the back right window is stuck rolled down.. how do i get it off the track
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The first thing I would check is the fuses. For this, they’re usually in the car on the driver's side. Refer to the fuse guide on the cover and verify it with a multimeter. If you don't own a multimeter, gett a $50-100 auto-range True RMS multimeter, such as a Klein like this: https://www.lowes.com/pd/Klein-Tools-Dig... ($60, 4,000 count) or this: https://www.lowes.com/pd/Klein-Tools-Dig... ($100, 6,000 count). In hindsight, I'd probably have spent the extra $40 and gotten the 1000V 6,000-count version over the cheaper 4,000-count version; I'd have spent the money - you'll probably be glad you did.
If you do not intend to use it beyond DC work, a relatively inexpensive Cat III from a place like Harbor Freight is an option. Try to get one with Cat III, Cat II and older should be avoided. This one is lacking TRMS, which means it will be prone to inaccuracies on non-linear circuits, but it is cheap at $40 (and you can probably use a coupon to get it down more): https://www.harborfreight.com/electrical...
If you do not see any bad fuses, then the next step I would take is to check the wiring on the car where the switch is and verify that the harness is receiving power. If you see 12V on the harness connected to the chassis, then we know the car is receiving power. You can usually remove this from most GM products from this era by removing one screw, but some have tabs that are easily broken. In this case, you need to use extreme care or remove the door card and dislodge them from the inside to avoid damage.
This is for the 2008 year, so it should be the same for 2008-2012, but if you want an exact diagram, search: (model year) Chevy Malibu electrical diagram: https://www.scribd.com/document/71455532...
If you’ve checked both of these and it isn't off track, where you can remove the door card to reseat the window, then the regulator is bad. At that point, without a model number, we’re stuck, but if you search (Model year) Chevy Malibu (bad) window regulator. At that point, I would also look for a matched year service manual to make sure you have the correct procedure for your car, as it can change slightly between years.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Skyler Lockwood sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 27
Her zaman: 458
