How do I wire up the vsr trigger switch
I have a new switch I need to install on the drill bit don't know how to wire it
A
Bu iyi bir soru mu?
A
Bu iyi bir soru mu?
I don't know if wiring diagrams are available for your drill, but generally my process is to open the drill up to get to the switch, then use the existing switch as a guide to where each wire goes. Take one wire at a time and move it from the original switch to the corresponding point on the replacement part. Is there a reason that won't work for you?
Bu yanıt yardımcı oldu mu?
To much time between new switch arriving. Took old switch out to get part number and. Don’t remember sequence to put back
@tony20811 How many wires go to the switch?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 76
