Ana içeriğe geç
Officially released on November 10, 2023. This is budget-friendly smartphone boasts a large 6.74-inch display with 90Hz refresh rate.
How to repair a cellphone lcd screen
I At that time my cellphone fell to the floor and the cellphone didn't use tempered glass so it cracked. How do I repair the LCD glass without having to replace the LCD?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Modern phones bond the LCD and digitizer to the front glass. Separating them generally requires using a vacuum table to hold down the display while you use a fine wire to separate the glass. Following that you'll need to clean the old adhesive completely then add a layer of optically clear adhesive (OCA) between the new glass and the LCD. Put the assembly into a vacuum chamber to remove the air bubbles, then into a UV chamber to cure the OCA.
Kind of a lot of trouble and adhesive, assuming you can even find the front glass; that may or may not be available for you particular phone. I would suggest just replacing the complete screen assembly; a quick search online shows some inexpensive screens selling for anywhere from $15 to $30 USD. Here are a couple of the cheaper examples I ran across with just a cursory search.
6.74" High Quality For Xiaomi Redmi 13C LCD Display Touch Screen Digitizer For Redmi 13C Display LCD 23100RN82L Replacement Part - AliExpress 509
Wholesale For Xiaomi Redmi 13C 4G / 5G / Redmi 13R 5G / Poco C65 4G Grade B LCD Screen and Digitizer Assembly Part (without Logo) Custom Available - TVCMALL
I wasn't able to locate a written guide like iFixit provides, but there are YouTube videos available, such as this one.
REDMI 13c LCD Replacement - YouTube
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
dawaaa sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 58
Her zaman: 380
