Ana içeriğe geç
Apple tarafından Haziran 2004'te tanıtılan 20 inç, 23 inç ve 30 inç alüminyum LCD ekranlar. Sırasıyla A1081, A1082 ve A1083 model numaralarına sahiptir.
Large Yellow Bar Running Vertically
I purchased this display used, and I haven't had any problems with it until recently. A thick, faint yellow line has been showing up vertically through my screen. Restarting and unplugging hasn't worked. After it's been on a while, sometimes it will disappear, but lately—it's been staying all work day. Does anyone know what's causing this? Photos below!
Resim
Photo #1: Screen with yellow line issue.
Resim
Photo #2: Original cord has electrical tape on wire. (I bought it like this.)
THANKS!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
5 Yorum
Howdy there, has the display been moved in a way that could have damaged it? Also is this the display the 27" model that only have the thunberbolt and magsafe connector shown here?
tarafından Paylaş
@jmehnert - These are the older DVI connection and you need a DVI to mDP port or Thunderbolt port adapter.
tarafından Paylaş
@jmehnert Hey! Thanks for your reply! Yes, it's the 27" model. Your link took me to the main "repair" area—I didn't see a specific magsafe connector image to compare the two!
tarafından Paylaş
@danj I'm not sure I follow. I have my Thunderbolt connected to my computer using this adapter: https://www.apple.com/shop/product/MYH93... It's been fine until now the yellow bar is showing up.
tarafından Paylaş
@reneeswigert - This is the older DVI model, yours is a TB2 with a TB3 adapter for your systems USB-C connection. As it turns out the TB3 interface offers multiple services old USB, mDP and USB-C based as well TB!
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This is a kind of TAB error when the LCD glass and the flex cable are bonded together a connection can get broken which in this case causes the yellow bar. Sometimes massaging the interface can get it reconnected. But that will require a bit of disassembly to gain access to the back of the LCD panel.
While the cord is cracked which is likely why it's taped, you might be able to locate a replacement cable.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks for the insight! I'm pretty handy (as long as it doesn't involve soldering!), and I don't mind opening it up per the ifixit instructions I saw. I picked this monitor up for $150, so I don't have that much into it. Can't hurt to try!
tarafından Paylaş
Hi Renee, have you fixed the yellow lines? I'm having the same issue with my Thunderbolt Display
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Renee sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 32
Her zaman: 411
