Ana içeriğe geç
Nintendo tarafından Switch sistemi için üretilen, kablosuz ve daha geleneksel bir video oyunu kontrolcüsü. Model numarası: HAC-013.
My pro controller doesn’t charge
I just replaced the battery in my pro controller thinking that it was a bad battery, it lasted for a while but when I went to change the controller it wouldn’t charge and now it only works when plugged in, what could be wrong?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Caleb!
Okay, so when you keep it plugged in, it works all fine?
It does sound like a broken battery.. Maybe the replacement part is faulty too. I would return the battery and get yourself a new one again and see how that goes.
If the exact same issue is happening again, then you might want to check the motherboard as well.
Please let us know how it goes!
Bu yanıt yardımcı oldu mu?
Puan 2
6 Yorum:
Thank you, I will let know
tarafından
Thanks Caleb!
tarafından
Update on my pro controller just randomly when I was using it while plugged in I noticed that it showed the battery was fully charged so I unplugged it and it worked just fine. Weird hun?
tarafından
So now it is working fine?? Then it is most likely related to the battery. You can just try and use it as it is now, or replace it and see how that goes!
tarafından
Yep it’s working fine now the only other problem is the left sticks pad has snapped off and the mechanism itself sticks in some positions but besides that it’s in great condition
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Caleb Skatvold sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 267
