Ana içeriğe geç
A line of external hard drives by Western Digital, styled after hardbound books. Available in various editions from Essential, to Premium to World Edition.
How do I fix the loose USB connection port?
The HD can no longer connect to the computer. It had a loose USB port, which by jiggling would eventually connect. Now, no amount of jiggling allows it ti connect. It powers up fine. When I try insert the USB cable into the port it falls in.
Western Digital My Book Essential 1.5TB USB 2.0 External Hard Drive WDBAAF0015HBK
Bu iyi bir soru mu?
Puan 4
1 Yorum
Western Digital My Book Essential 1.5TB USB 2.0 External Hard Drive WDBAAF0015HBK-NESN
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
this is the disassembly you could use to get to the USB port. If you are ok at soldering then I'd try resoldering the legs to the motherboard-with time and putting the cord in and out something has wobbled free and contact is broken. Obviously try this without the hard drive attached to the board...
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I have made my posting clearer. It is a great site but not for my drive.
tarafından
Yorum Ekle
You will have to open the drive and see if the USB female plug is damaged and connected to the circuit board.
If the plug has been broken off the board, you may need to carefully solder it back to the connections.
Depending on damage, you may have to replace the board with one that is an exactly the same and it has an identical parts number because your drive may use hardware data encryption.
Puan 1
1 Yorum:
Another point: Since some Western Digital drives use a special chip on the drive electronics to encrypt the data, placing the drive in another enclosure with different electronics may not work. Windows may not even detect the drive. What ever you do "don't initialize" the drive because you'll erase the data.
tarafından
Yorum Ekle
Yanıtını ekle
Israel Fajardo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 25
Her zaman: 48,453
