I need password system bios
I'm trying to types password is rejecting and I'm trying to
Set up and to boot menu is all rejecting
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I am going to expand on @dinoo_fixit's answer as they missed key details. When you get the master password, it's case sensitive. On the D series and early E series machines you enter it and press Shift+Enter, then it will get you in. The key here is on Core 2 era E series machines it just gets you past the initial prompt - you need to make it permanent as if you were setting a new one. The trick is you need to go into the security menu, put the master password in the administrator password box and leave the other boxes blank - this will clear it out. Once you do that, save the changes and exit the BIOS.
Bu yanıt yardımcı oldu mu?
Thanks, this should be the accepted answer
It is a very old laptop, first of all disconnect/reconnect CMOS battery for an initial reset (Dell Latitude D630 CMOS pili değişimi) and then use a tool like this (https://bios-pw.org/) to insert serial number/asset tag and get a recovery password
BIOS battery hasn't worked since the C6XX series. Master password is the only way.
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 325
