Ana içeriğe geç
Standart hibrit güç aktarma organına sahip, altıncı nesil Toyota Camry.
dash cam power connection
what kind of connector does the dash cam use?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Depends on the dash cam - a lot of them rely on the 12V cigarette lighter, but as cars begin to drop it they will rely more on USB-A and USB-C. Some allow you to hardware it into the car, but that comes with a massive implication: F the process up, and you risk a denied warranty claim - DON'T DO IT on a new vehicle. I've just used USB hubs in new vehicles that support it and retain CarPlay/Android Auto over a hub.
The other option is to piggyback off of one of the higher amp fuses (or if you have an option that isn't present on your car but the fusebox has the right amp support), you can use that dormant fuse slot as they use the same fuse boxes across the lineup and just delete unused fuses. VW omits the unused wires, but most do not - check for conductors inside and if you see them, use it.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
STEVEN CODRINGTON sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 471
