Ana içeriğe geç
32 veya 128 GB depolama seçenekleriyle sunulan, 7. nesil Apple iPad Wi-Fi modeli için onarım kılavuzları, söküm ve sorun giderme bilgileri. Eylül 2019'da piyasaya sürülmüştür. A2197 model numarasıyla tanımlanır.
TG0B Kernel Panic
Got the same issue
I replaced the battery but still getting the TG0B error. The battery level is fluctuating as well. I checked the capacitor C8923 and I got diode resistanc f .883 not sure if this is too high. FL8900 is good as well. What Iam not sure is the Q8900 which for BATT_SWI_FL.
The C8922 which is for BATT_NTC is ok as well it go straight to PMU chip. I tried to jump a wire from the battery terminal directly to batt_ntc n C8922 in case the connection going to the battery is loose but still getting TG0B ... This issue is a pain.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Migrated from this question.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Did you screw in the battery all the way? I had this error as well on my iPad 7 after a logic board swap. It kept having a kernel panic and reboot every 1-3 minutes or so, and the battery wouldn't charge anywhere past 19%. Turns out I forgot to screw in the battery which was causing the connection between the logic board and the battery to be weak. Try screwing the battery if you need to, if not, then not all pins might be making a connection which would require some soldering.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Jerson Macapanas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 30
Her zaman: 232
