Ana içeriğe geç
Sony WH-1000XM3 kablosuz gürültü engelleyici kulak çevreleyen kulaklık için onarım ve söküm bilgileri.
Vocal frequence almost gone
Hi, I have these once wonderful headphones, but it seems they now won’t work as before. They seemingly charge, with the light showing red, but the power button really doesn’t evoke them, except very seldom. Sometime also randomly, on its own and then they won’t turn off.
As for the sound quality, the whole middle register, especially vocals, seem to almost vanish into the background. This is regular, even when playing cable only.
I’ve disassembled them according to the given instructions without finding any obvious weak connections. A little rust on the head of two of the long screws was all I could spot.
Any hints? Are they worth repairing, or should I consider recycling them?
-Glenn
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
I think it's worth trying to repair them:
  • regarding the battery I think now they have ~7 years, time for a replacement (it may/should fix the power issues)
  • regarding the audio issues, take a multimeter and check the resistance between start/end point of the cables, it might be due to some cables rupturing internally (they're very thin), if it's very high (or infinity) you got the culprit and got to replace the cable. Also you might try to rework all the solder joints (remove old solder, clean, apply new), especially if some look like "cold joints"
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Glenn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 11
Son 30 gün: 21
Her zaman: 145
