Ana içeriğe geç
28 Eylül 2023 tarihinde duyurulan Raspberry Pi 5, Raspberry 4B'nin donanımının bir revizyonu olarak işlev görür.
Pi is not booting up
I connect ot to the power supply and it shows red light, (my pi camera was shorted and burnt a bit from since my pi is showing red light) it is not showing green light, fan doesn't spin and a minor current i feel when i turn it on any fix?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
troubleshooting steps:
  • See if a pc can recognize the device.
  • Reprogram the firmware
  • Check if the SD card is working properly
  • Check the voltage rails on the GIPO header pinout is found here
Resim
how to change boot mode and other pi hardware documentation is found here
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
@prasadgawas since this happened because "my pi camera was shorted and burnt a bit from since my pi is showing red light" you do want to go ahead and repair that damage. Anytime you have a shortened component you will have top replace it first and check all of the traces as well as other components which may have shortened out as well. Go ahead and post some good pictures of your Pi5 with your question so we can see what you see.
Since this is physical damage, no firmware update etc. will work for this
Puan 0
Yorum Ekle
Yanıtını ekle
Prasad Gawas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 626
