Ana içeriğe geç
5 kapılı Explorer ve benzeri olan Mercury Mountaineer, 2002 model yılı için tamamen yeniden tasarlanmış ve ağabeyi Ford Expedition'a benzer bir görünüm kazanmıştır.
Turn signal stops blinking.
When I turn on my turn signal, sometimes it doesn't blink at all. Other times it blinks a few times and stops. The control lever was broken when I got the vehicle and I thought that was the cause but replacing the lever did not fix the blink issue.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Here are the next troubleshooting steps I recommend
  • Replacing the flasher relay is cheap, easy, and likely the solution to your problem VIDEO GUIDE
  • Checking the signal lamp Frame grounding point
    • There should be a wire that attaches straight to the frame from the headlight assembly. Remove it and sand underneath to remove any rust or corrosion, and replace it.
    • Here are the signal lamps' electrical schematics
Resim
Resim
These are the easy things to check. If this doesn't get you there, I'd recommend consulting a professional auto mechanic.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Dan S. sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 180
