Ana içeriğe geç
PowerMac G5, Apple Corporation tarafından ilk kez 2003 yılında üretilen bir masaüstü bilgisayardır. Bu kılavuz, 2004 yılına ait A1047 EMC 2061 model numaralı Apple PowerMac G5'in onarım sürecini inceleyecektir. Intel geçişinin bir parçası olarak önce geliştiriciler, ardından tüketiciler için 2006 yılında üretimi durdurulmuştur.
Help Identifying a Part from a G5 PowerMac
I'm currently reassembling a 2005 G5 2.0 GHz DP, M9747LL/A.
I have the following part but I can't remember where it came from, and I've not documented it in my photos I took during disassembly.
Can anyone help identify it?
Thanks.
Resim
Resim
Resim
Resim
Bu iyi bir soru mu?
Puan 0
2 Yorum
What did you do? That might offer a hint where to look.
tarafından
I did a complete teardown as it was the most filthiest computer I've ever come across.
It was likely removed after the motherboard came out. Maybe somewhere around the HDD holders.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It's been quite awhile since I've worked on these older systems I keep thinking it's a logic board stand off holding the board off of the side panel (bottom side of logic board). Just behind the PCI slots you should see some holes where the pins and latch tab pass through to secure it.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I've added two more photos, do you mean in that area?
I realise it's a bit vague, and it is my own fault for not paying enough attention when taking it apart. But I do appreciate everyone's input on this.
tarafından
Found it, it covers a cable on the lower left of the board near the RAM slots.
tarafından
Yorum Ekle
Yanıtını ekle
David sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 17
Her zaman: 209
