Ana içeriğe geç
Google'ın Ekim 2022'de piyasaya sürülen Pixel 7 akıllı telefonu için onarım ve sökme bilgileri. GVU6C ve GQML3 model numaralarıyla tanımlanır.
Screen detached from plastic safety frame
The battery was swollen and pushed the screen out, and when opening the phone I didn’t realise that instead of separating the screen with its frame from the chassis I was actually separating the screen from the safety frame.
Resim
The photo above should make it clearer.
Now I imagine the obvious answer would be to get a replacement screen but tbh having already spent 80€ for the battery kit I don’t think it’s worth it (also the screen is fine)
Any chance I can reassemble the screen and frame? What glue could work?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
I ended up carefully cleaning frame and screen with isopropyl alcohol, then used a thin layer of T8000, let it dry a few hours before proceeding with reassembling the screen to the device, and finally leaving the phone under a stack of books for 24 hours.
I guess I'll have to report back in some time to see if it holds, but for now the result was quite good. It's most likely not waterproof anymore but I mean, at least it won't blow up anymore.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Giorgio sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 219
