Ana içeriğe geç
Nintendo'nun 3DS ailesindeki ilk büyük revizyonu; Ekim 2014'te Japonya'da, Eylül 2015'te ise Kuzey Amerika'da piyasaya sürülmüştür. 2015 model 3DS; geliştirilmiş 3D yetenekleri, bir adet C-Stick, yeni dahili amiibo desteği ve yeni tetik tuşları takımı ile gelmektedir.
New 3ds lcd issue
Good day ladies and gents
I have a new 3ds of which I have an issue with the lower screen. The device powers on , but only the top screen shows up. The bottom screen is black but the touchscreen works. I have replaced the lcd bottom screen twice but to no avail. The ribbons are secured, the ribbon clip is fine and clean. This applies to the lcd and light connectors. Could I ask if there is anyone that has a solution please
Many thanks
Tobi
Bu iyi bir soru mu?
Puan 0
1 Yorum
This question was migrated from https://meta.ifixit.com/Answers.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Tobi!
Well, then it’s most likely motherboard related. Does the screen shows anything? Maybe the blacklight is just dead. You can check with a flashlight on the screen.
In the worst case, a motherboard replacement is required.
If you can sent any photo, that would help, thanks!
Please let us know how it goes!
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Hi there. I did think it would end up being the lighting issue. I will try and get some photos accoss on here. And thank you for your response 🙂
tarafından
My pleasure! That would help, thank you :)! Then it's most likely something on the motherboard causing this issue. Can be a lot of components. Running tests is required to check for the backlight!
tarafından
Yorum Ekle
Yanıtını ekle
SplitPancreas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 224
