Ana içeriğe geç
DeWalt DW311, kablolu bir panter testeredir.
How to replace power cord?
Resim
Resim
Resim
Resim
The black cord seems to be hard wired into the switch. How to separate and replace just the cord?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
@alienamerican looks like the power cord is available without the switch. That would mean that it is somehow possible to remove the cable from the switch. I wonder if there is a push connector on the switch for the cable. Post some good pictures of your switch etc. with your Question. That way we can see what you see and hopefully come up with a solution. Mevcut bir soruya görsel ekleme
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
Added some photos. This little black box looks like it should open, but nothing I've tried seems to work
tarafından Paylaş
@alienamerican what a PITA. I absolutely dislike when they make things so complicated. Yes, it does look like it comes out. The trigger seems to operate some sort of lever that moves the contacts on the inside of the switch. Honestly, at this point I would just cut the wires, solder the new power cord to the tails and apply some heat shrink tubing for insulation.
tarafından Paylaş
Good idea. I'm gonna just do that
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Alienamerican sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 39
Her zaman: 412
