Ana içeriğe geç
Samsung 28" 4K UHD Monitör. Model #LU28E510DS/ZA.
Guide to remove front panel layer
I have a bug that crawled behind the lcd front panel layer and died. Is there a guide on how to remove the front panel layer to dislodge the bug?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@jameshigh you will have to completely disassemble your panel. for that you have to tear down your monitor. There are no guides for that.
You can use the guides from here Samsung U28E510 to get into the monitor. Then remove all the boards and check the panel. There might be a removable frame. If so, then disassemble it by removing the frame. There should be a few diffuser sheets etc behind the actual display panel. Keep those in the original order and direction that they are in. Otherwise you will have display issues after.
Post some good picture of the actual panel once you removed all the boards etc. That way we can try and assist you further with this. It's a lot of work for a bug. It might just be easier to leave it where it is and try to live with it :-).
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
James High sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 40
Her zaman: 239
