Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Soru Tümünü görüntüle
No Backlight
i need help on how to get back the light on my iphone it is very dark and i know it is the backlight problem but i need help to know how to fix it im scared to open it apart and miss the whole thing up!!!! please help!!
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Layla. It seems you might need to replace the Display Assembly. Feel free to use our guide and let us know if you need any help. Best of luck!
iPhone 3G Display Assembly Görseli
Ürün
$59.99
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Although replacing the entire display assembly is undoubtedly the easiest solution, particularly for the less tech inclined, it may not actually fix the issue. Replacing the components responsible for this function is likely to be what's required. But, it does entail desoldering and soldering of 1 or both components on the mother board. See this source, it provides a great zoom pix of component location http://www.amazon.com/CyberDoc-LLC-iPhon.... You can buy both components very reasonably or separately from a NYC vendor.
tarafından
Yorum Ekle
Yanıtını ekle
layla ahmed sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 968
