Ana içeriğe geç
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
How can I remove line on my screen?
How can I remove lines on my screen? Am using iMac 5,1 17 2006 products, the lines are verticals and very thin and it keeps on multiply with different colours namely blue, yellow, and pink the lines merges to black any time I put on the pc for about five to ten minutes, the lines keeps remaining on the screen.
Bu iyi bir soru mu?
Puan 1
2 Yorum
More information is needed. What computer--what screen--where is the line--how does it run (up&down--left&right)--how big is it and so on. Ralph
tarafından
Am using Brobook G4 17", when I fix the memory on the slot it doesn't work but at times it works, what is causing the problem, because I've fix in new memory and still it doesn't work.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Connect the iMac to an external monitor to check if the problem is a graphic card problem or a LCD panel issue. A normal video signal on the external monitor would lead to a LCD display issue related to a bad LVDS cable or bad LCD panel.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Johnson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,710
