Ana içeriğe geç
HP 600 dizüstü bilgisayar serisi için onarım bilgileri.
My laptop won't charge
I have two HP laptops. One of them won't charge using the same charger. If I charge the battery on the first one and place it in the second laptop work fine. I disassembled it and checked for the DC power jack, and it worked perfectly. Any ideas about what could be the problem?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum
Have you tested that the battery of the non-charging laptop works? If not, try putting that battery in the laptop that won't charge and see if you get the same issue.
tarafından
@havynkrentz battery works perfectly. I guess there's some problem in the motherboard. Everything works as it should, except it won't charge.
tarafından
@anwar29099
What is the full model number of the laptop that doesn't charge?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @anwar29099
Here are the motherboard schematics that should help.
Go to p.8 and following the DCIN path from pin 1 of the DC-IN cable connector on the motherboard to see how far you get. Also check that the circuits connected to the other pins i.e. 3,4 &5 are also OK
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Anwar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 150
