Ana içeriğe geç
22 Eylül 2017'de piyasaya sürülen iPhone 8 için onarım bilgileri ve kılavuzları. Model: A1863, A1905
Connector different from iPhone 8X
New iPhone8 battery from iFixIt will not connect - the connector on battery and in phone seem to be the same, but will not "snap" into place. Might I need an iPhone8X battery? Any other suggestions?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
There is no iPhone 8x or do you mean the battery or your phone is different than what the battery was intended?
Look at this image which is your phone?
Resim
And then look at the iFixit battery it should tell you which phone it's intended for.
If it's correct, look at the battery connector both the battery and the phone are any of the contacts damaged or the plastic pushed in blocking the connection.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
@pleasedont46099 iPhone 8 and iPhone 8 Plus share the same battery connector. Physically, the 8Plus is a larger battery and will not fit a regular iPhone 8. Double check your phone to figure put what model you have. You can use this site for that Of course, you can also try that by the battery connector
Resim
If in doubt, take some well focused pictures of the battery connector and your replacement battery (if you still have the old battery, a picture of that as well) and post those with your Question. That way we can see what you see and hopefully find out what's going on with this. Mevcut bir soruya görsel ekleme
Puan 0
Yorum Ekle
Yanıtını ekle
PleaseDontCreateAnAccount sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 136
