Ana içeriğe geç
Nisan 2025'te piyasaya sürülen Google Pixel 9a akıllı telefon için onarım kılavuzları, söküm ve sorun giderme bilgileri.
Pixel 9a Screen replacement problem, I need advice
While removing the shattered screen I damaged the upper right "silver foam pad" described in step 21 below, also a little tear in the black taping above it
Google Pixel 9a Ekran Değişimi
Should I attempt to install the new screen ($120) or return it and buy a new 9a for $300
Resim
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The silver foam pad is just a grounding connection. Just re-form it as best you can; it will almost certainly still do its job, and besides, there are at least four more to do the job, so it's highly unlikely to cause you any problems. Likewise the tear in the tape is inconsequential; it's not going to hurt anything the way it is.
It's always advised to plug the screen in and reassemble far enough to power it on before you glue down the screen anyway, and by doing so you can verify that everything's working correctly before you disconnect the battery again and apply the adhesive.
Long story short (or TL;DR as they say), you're fine; you haven't done any serious damage and there's no reason the phone shouldn't work perfectly after you put it back together.
A fellow Pixel owner
Bu yanıt yardımcı oldu mu?
Puan 3
4 Yorum:
Jerry, thanks for the info. I went ahead and attached the screen, fired it up and all is well, unfortunately when I powered down the phone to finish I discovered the screen did not have the preinstalled adhesive nor was there the other screen adhesive listed in "Kit contents", so I will have to get the adhesive to finish my repair. It wasn't easy, but it's looking like it will be a complete success.
Thanks again
tarafından
@jimd48312 Did you buy the screen alone, or the Fix Kit version? Neither one comes with the adhesive already attached to the screen, but the Fix Kit does include it as part of the kit. There are blue stickers on the screen, but they're just to protect the screen and aren't covering adhesive.
If you did get the fix kit and the screen adhesive was missing, contact the Store personnel at support@ifixit.com and I'm sure they'll send you one.
tarafından
I did buy the "Kit" and after two emails I had the adhesive in a couple of days and the phone is like new again.
Thanks for your help
tarafından
@jimd48312 That's awesome, Jim! So glad to hear it all worked out for you; thanks for letting us know.
tarafından
Yorum Ekle
Yanıtını ekle
JIM D sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 12
Son 30 gün: 33
Her zaman: 1,002
