Ana içeriğe geç
Chrysler'ın Jeep bölümü tarafından üretilen, üst sınıf orta boy bir SUV olan birinci nesil Grand Cherokee ZJ için onarım rehberleri ve destek.
My distributor is not working
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum:
@notic why do you think your distributor is not working? What symptoms does your Jeep have? What model and engine size is it? What have you checked?
tarafından
It doesn't send high voltage electricity from the ignition coil to the spark plugs in the right sequence to deliver a spark which ignites the fuel / air mixture to run the engine.
tarafından
1993-1998 Jeep Grand Cherokee ZJ
tarafından
Double check you have the sparkplug wires going to the correct cylinder. Take off the cap and clean off the carbon traces and look for damage.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
@notic the distributor is the last thing that I would expect to have failed. My primary suspect is the crankshaft position sensor. Check for the 5.0 volts that comes from the Engine Computer to run the sensor. That same 5.0 volts also feeds the distributor pickup coil, (camshaft position sensor). If you do not have the 5.0 volt with the ignition switch on, one of those sensors has failed. Now, for a more in-depth way of testing those we will need to know the exact year and engine size for your Jeep.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Notic sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 212
