Pump not working well
Pump is not working, the pump is too low to working
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If the pump is running but producing low flow or pressure, first check for blocked tubing, clogged filters, air leaks, or low fluid levels. Also inspect the pump inlet and connections for loose fittings or restrictions. If the issue continues after these checks, the pump may need servicing or replacement of worn internal parts.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 37
Her zaman: 183
