Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1960 Soru Tümünü görüntüle
iPhone shuts down randomly when asked "too much"
Hey all !
I've been using my iphone 3GS for about two years now, and it started shutting down randomly a few months ago. It keeps getting worse and worse.
It usually shuts down when I'm trying to access the web (via app or Safari), but it also crashes when I'm done with a call, or when I listen to music. The thing is I can't boot it back on without connecting it to power.
I don't know if it could be the battery, because sometimes it holds the whole day with no particular issue...
What do you guys think ? :)
Thank you !
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Paul Helbert, it is at least two years old, and the battery may be coming to the end of its lifecycle. The errors you are describing would fit this. idevices, especially the iPhone. do demonstrate the weirdest, most inconsistent errors. I would most certainly start with it. Check this guide and as you will see, it is not a terribly difficult job, and not to expensive, but it will provide you with a known good starting point for any further trouble shooting. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Paul Helbert sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 1,460
