Ana içeriğe geç
How do I reverse the direction of the lock tongue?
What I mean by tongue here is the part that goes in and out when the door is opened or closed.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
Hi @feelingsly
What is the make and model number of the door lock?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
  1. Use the appropriate tools: a regular or electric screwdriver, and sometimes a wedge to stabilize the door while you work. Unscrew the side screws: Using a screwdriver, loosen the screws that secure the lock to the door.
  2. Remove the lock: Gently pull the lock out until the lock tab is exposed.
  3. Turn or replace the tab: Some locks allow you to turn the tab directly without completely disassembling it.
  4. When removing the lock, insert the screwdriver and the hole, press until the tab pops out, and then rotate the screwdriver as shown in the picture.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
feelings ly sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 21
Her zaman: 50
