Ana içeriğe geç
GMC Sierra dahil olmak üzere General Motors tarafından GMC markası altında satılan C/K kamyonetler için onarım rehberleri ve destek.
How can I fix or replace dash gauges?
Update (09/06/25)
@oldturkey03 Yeah it's a 94 GMC Sierra k1500 .
Seems oil pressure gauge(which I changed few years ago/failing to start) started too be erratic, year later or so the temp gauge goes rt too hot when running a few seconds, (pump replaced years ago, coolant good and no overheat). I changed sensors/wires (two), cleaned MaP sensor, checked grounds, found one broken but had no effect when connected. Didn't replace thermostat yet but have it, my guru says it's likely gauges going, there's motors in them that die off, short of tearing things apart thus breaking clips etc, what else is good or how to take out the cluster and replace it or gauges etc on the very cheap low expense end.
Seems The air/fuel mixture due pcm being told it's running hot (which happened years ago w broker fan belt) causes choking when stopped like it's timing is off-rumbling sensation. Worried about damaging worse then already may have driving
Bu iyi bir soru mu?
Puan 0
1 Yorum
@glentrs what exact year and model is your Pickup?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@glentrs I'd remove the instrument cluster and take a look at the back of it. See if there are burned/corroded traces etc. To remove the cluster use the service manual page 262. You can now download it from this page 1988-1998 GMC Pickup under the Documents Tab. For a more in-depth information about your cluster, look at the 1994 CK Truck SM that you can get on the same page. Check page 1280 in that manual.
Once you have the cluster out turn it over and take some pictures. Let's see if we can find anything odd looking on it.
Mevcut bir soruya görsel ekleme
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Ok OT ! I need a few days to get car running good so I won't be without. THANKS for the leads !
tarafından
Yorum Ekle
Yanıtını ekle
Glentrs sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 27
Her zaman: 308
