Ana içeriğe geç
Why is it not turning on but only showing red lightning
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@kadafimotingwa that lighting bolt means that your phone has a very low battery or is completely dead. The very first thing you want to do is to charge your phone, IF it does not charge then the issue could be a bad battery, a bad charging board or even a bad charger/cable. Check that first. Clean your charging port with a few puffs of compressed air. If that still does not work, replace the battery and re-evaluate.
Since iFixit does not yet have a specific guides for this, use something like this video Replacement batteries are readily available at many online stores.
If your phone has other issues then having to replace the battery, you need to be more specific with your question.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Kadafi Motingwa sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 16
Son 30 gün: 54
Her zaman: 92
