Ana içeriğe geç
Olympus OM-1, 1972 yılında devrim niteliğinde bir 35mm SLR olarak piyasaya sürülmüş olup, rakiplerinden belirgin şekilde daha küçük ve hafif bir gövdede profesyonel düzeyde, tamamen mekanik bir sistem sunmuştur. Parlak bir vizöre ve deklanşör hızı kadranının üst plaka yerine lens yuvasının etrafında bulunması gibi benzersiz kontrollere sahipti.
Maintenance question for OM-1N
I picked up a near mint OM1n from ebay, and i really want to keep it in mint working condition but where i live (island nation) there are quite literally zero shops that specialize in vintage repair/maintenance cameras, let alone Olympus systems. And i dont feel like sending it overseas.
My question is basically this, is there any guide/video tutorial out there that shows and explains a complete CLA process for the OM1 or similar cameras? Im aware im no technician but i can follow specific instructions on my own risk, specifically what kind of lubricants/grease to use, when & on which parts, how to disassemble exactly whats needed and put everything back together. I tried youtube but it doesnt go much further than light seal replacements and prism foam cleaning.
Basically the most basic maintenance a professional would do to prolong the life of the camera.
Or at least as much as a regular person with normal precision tools can perform at home.
Thank you!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You can find the repair manual for your camera online as a PDF from a few sources. Scan example here's the older version Olympus OM-1 service manual here's the rest of the manual grab the last one gets into lube OM-1 & OM-4 maunals
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
now where is a copy for the OM2n ?
tarafından
@om1gc - The mechanicals are the same across the OM-1 series. Only the metering and flash circuits are a bit different.
tarafından
@om1gc see if the manuals on here Olympus OM-2 under the documents tab will work for you.
tarafından
Yorum Ekle
Yanıtını ekle
DBCooper sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 53
Her zaman: 885
