Ana içeriğe geç
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Soru Tümünü görüntüle
MBP makes strange noise (left fan?)
Hi community!
Since today my MBP (mid 2010) makes very strange noise. It comes from anywhere near the tabulator key. I just opened my MBP, under the tabulator key is the left fan.
I made a short video to demonstrate the noise:
http://www.youtube.com/watch?v=Bgee3A47Q...
Please help me, I have important examinations in two weeks, my laptop is very important for me! :-/
Greets
Klaus
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Thanks for the video. Yes this sounds like something is pressing against the fan. I would first check to see if the attachment cable is getting caught and pressed into it. That failing I would remove the fan to see what could be pressing against it. As I always recommend, users should always use an external hard drive for Time Machine backup. These things are cheap now, under a hundred dollars and can save you a lot of greif if you ever lose your hard drive or, God forbid, your Book. Here's how to do it: MacBook Pro 15" Unibody Mid 2010 Left Fan Replacement
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
thank you, i give that a try!
tarafından
does it work? i have the same issue.
tarafından
Yorum Ekle
Yanıtını ekle
Klaus Hiesmayr sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 3,789
