Ana içeriğe geç
Predecessor to the Compact Fluorescent Light. Invention is credited to Thomas Edison in 1879.
My light always burn out when I turn them on
Why do the light burn out when I turn them on
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@thulanemosia first you want to make sure that you have the right light bulb for your lamp as well as for your standard household voltage. If you are sure that you have the right bulb, you will need to check the bulb socket. It is possible that your bulb is actually creating a short circuit (which will then immediately burn out the filament of the bulb) when you screw it into the socket. Remove the lamp form the power supply and check the two conductors. There will be a center one and the other one will connect to the threaded part. Make sure that they are no loose and/or accidentally touching etc. Always make sure you disconnect the lamp from the power line.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
If new light bulbs always burns, there's a chance that overvoltage appears (maybe 380VAC instead of 220VAC, for example)
Puan 0
Yorum Ekle
What bulbs are you using? Is your power 120v or 220v based? Using the wrong voltage bulbs can cause them to fail.
Puan 0
Yorum Ekle
Yanıtını ekle
Thulane Mosia sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 63
