Ana içeriğe geç
iPhone 13 için tamir kılavuzları, el kitapları ve sorun giderme yardımı. iPhone 13 cihazınızı kendiniz tamir etmek için ihtiyacınız olan her şeyi edinin.
Side buttons and screen will not function after screen replacement
Title says it. None of the side buttons do anything anymore. Also put new screen on it, phone powers up but not the screen. I’ve done the basic troubleshooting checking the connectors and ensure clean. Carefully switched the sensor stuff over but can’t figure out why the screen won’t come on.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum:
Did you try to connect it to your computer? If it shows up in iTunes then restore it to see if that solves the issue. If there's data in it then back it up first.
tarafından
Did the side buttons function at all before replacing the screen?
tarafından
No I haven’t tried connecting to pc. Could it simply be just a software issue? Potentially of course. Is that what you’re sayin?
-no the side buttons quit before the screen swap.
-oh I made sure I was careful. I started fixing my phones ooooooh hmmm right around iPhone 8 era. This is the first time I’ve had one not work though. So 🤷‍♂️
tarafından
Tried connecting to pc and found softwares like reiboot. But they only work and force recovery mode IF you can establish usb connection. Which since phone is in initial power on state, you HAVE to punch in the screen passcode to do the initial screen unlock before the usb will work when the screen is locked in the future i guess.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Maybe you torn down the interface cable or just bad connected it? It's easy to destroy those cables when doing a self-made display replacement. To recover them, you'll need a microscope.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
busapower07 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 97
