Ana içeriğe geç
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Soru Tümünü görüntüle
Why is it that I chargedmy iPod and have a dead battery?
I charge my ipod as much as is needed but lately even though I've charged it all night it still says its dead or will only work if it's on the charger. If I try to play on it or do anything the temperture screen comes up and its not even hot
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Nychelle Gilliard, "will only work if it's on the charger" is most likely a battery issue. Replace the battery and reevaluate. Your battery most likely will not hold a charge. Other possibilities, which are not as easily fixed would be a bad dock connector. Check for any broken, bend, or corroded pins. Also check for dirt within the connector. Hope this helps, good luck
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Nychelle Gilliard sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 429
