Joystick drift when using L joystick
MY left joystick resist going to the left, afterwards it drifts to the right
Bu iyi bir soru mu?
Bu iyi bir soru mu?
To address your left joystick's resistance to the left and subsequent rightward drift, you should first try to clean the joystick with compressed air or a small brush to dislodge any debris, then update your controller's firmware. If these don't work, the problem is likely caused by internal wear on the potentiometers, which may require internal cleaning, replacing the thumbstick module, or professional repair.
Personal email address removed to avoid solicitating business
Bu yanıt yardımcı oldu mu?
Replace both left and right potentiometers with hall effect ones.
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 96
Her zaman: 1,124
