Seized Left Rear Wheel
my L/R wheel is seized,is it the rear hub unit bearing?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Donna, if it is a FWD model, it is possible that your hub has seized up. Of course, the only way to really determine this is to, jack up the car, remove the wheel, and remove the rear brake. Possibly that your break is causing this too. Check to make sure that the brake shoes from the parking brake are properly releasing, and the the brake caliper is not seized.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 1,570
7 Yorum
What is your definition of "seized"? what does it do and what does it not do? Did this just start? What type of transmission does it have?
oldturkey03 tarafından Paylaş
wheel will not engage forward or reverse,just happened,auto transmittion
Donna tarafından Paylaş
is it FWD or AWD?
Its All Wheel Drive
Same thing, check the brakes, see if you can release the brakes and if your wheel will turn. Possible seized bearing or seized rear differential :(
2 tane daha yorum göster
