Ana içeriğe geç
2015 yılında piyasaya sürülen HP EliteBook 850 G2, daha yeni işlemciler ve isteğe bağlı dokunmatik ekran özellikleriyle 850 G1 modelinin bir güncellemesidir. Onarım kılavuzlarını ve ayrıntılı bilgileri burada bulabilirsiniz.
My device doesnt powering on.
Device doesnt powering on..with battery or without battery, only charger.
When i press power on button,only keyboard lights turn on for a second, not ndisplay.after a second it turns off keyboard light too..
I opened the case.The fan spins when device got power.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum:
@dynamicrex does the fan spin normal, fast or just a little bit? What have you already checked?
tarafından
Fast spining fan
tarafından
Please Remove the RAM and check
tarafından
@dynamicrex Have you attempted to remove/reinsert the hard drive in addition to the RAM?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
This behavior usually points to a hardware power or motherboard issue. Since the keyboard backlight flashes briefly and the fan spins, the laptop is receiving power but failing POST. Try a hard reset first: unplug charger, remove battery, hold the power button for 30–40 seconds, then retry with charger only. Reseat RAM, SSD, and display cable. Test with one RAM stick if possible. If there’s no display even on an external monitor, the issue is likely a faulty motherboard, BIOS corruption, or power IC. In that case, professional repair or board replacement is required.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Mine did this after the battery died. Wouldn’t turn on with or without the battery, just flashed the keyboard lights. CMOS reset fixed it. Pulled the battery, held power button for ~30 seconds, then tried again.
Puan 0
Yorum Ekle
Well you can checkout the following video: https://www.youtube.com/watch?v=eHPTNKTg...
Puan 0
Yorum Ekle
Yanıtını ekle
Dynamic Rex sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 131
