Ana içeriğe geç
2013-2017 yılları civarında üretilen ThinkCentre M73 (10AX, 10AY tipi) "Tiny Form Factor" masaüstü bilgisayar.
System error when turned on
My pc shows an error message when turned on about product patents, client Mac address.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
cpu fan failure
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
  • BIOS/UEFI configuration issue
    • If the system can’t find a valid boot drive, it tries to boot over the network (PXE boot). That’s when you see Client MAC address and patent/product messages.
  • Missing/Corrupted DMI (Desktop Management Interface) info
    • Sometimes after a motherboard replacement or BIOS reset, system-specific info (like product number, serial number, etc.) isn’t written to the BIOS properly. HP, Dell, and Lenovo systems often throw “Product Information Not Valid” errors in that case.
  • Hard Drive / Boot Device issue
    • If your storage drive isn’t detected or has failed, the PC skips to network boot.
How to Fix-
  1. Check Boot Order
    • Enter BIOS/UEFI (usually press F2, F10, ESC, or DEL at startup).
    • Ensure your hard drive/SSD is listed as the first boot device, not “Network Boot” or PXE.
  2. Reconnect Storage Drive
    • Power off the PC, reseat the HDD/SSD cables (or NVMe drive) to ensure it’s properly connected.
  3. Reset BIOS
    • In BIOS, look for “Load Optimized Defaults” or “Reset to Defaults” and save.
  4. Check for DMI/Serial Info
    • If the error mentions product patents or product info not valid, it may require reprogramming the system board information (usually only a service center or manufacturer tool can do this).
  5. Disable PXE Boot
    • If you don’t use network booting, disable PXE/Network Boot from BIOS.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Gaone sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 53
Her zaman: 277
