Ana içeriğe geç
Ford Super Duty (ayrıca F-Serisi Super Duty olarak da adlandırılır), Amerikalı otomobil üreticisi Ford Motor Company tarafından üretilen bir kamyon serisidir.
How to fix computer code B1317:60
I ran out of fuel without knowing (dashboard doesn't work) on a slope. Tried to crank on and it failed so I leveled the truck the most I could on the road and still nothing. Fueled up 5 gallons and nothing. Had a mechanic bleed out the lines and gave the truck a jump from another truck and it will automatically shut off. So we checked the diagnostic system and it gives me codes B1317:60 ; B1352:60 ; and U1900:60.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hey there, from the codes and what you described, here’s what I think is going on with your truck.
B1317 means your battery voltage is low – could be a weak battery, bad connection, or the alternator not charging right.
B1352 points to a problem with the ignition switch or the wiring around it.
U1900 is a communication issue between the truck’s computer modules – usually wiring or a connector somewhere.
Since you ran out of fuel, it’s also possible there’s still air trapped in the fuel lines. I’d start by making sure the battery’s solid, check the ignition stuff, make sure the wiring/connectors are good, and prime the fuel system.
If it still won’t start after that, you might need a Ford guy to take a closer look, especially with the dash not working.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Lauro Perez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 32
Her zaman: 355
